TMP300,pdf (Resistor-Programma
消耗积分:5 | 格式:rar | 大小:660 | 2010-06-01
李敏
分享资料个
The TMP300 is a low-power, resistor-programmable,digital output temperature switch. It allows a threshold point to be set by adding an external resistor. Two levels of hysteresis are available. The TMP300 has a VTEMP analog output that can be used as a testing point or in temperature-compensation loops.
The TMP300 detects temperature with ±4°C accuracy (max) over -40°C to +125°C.
With a supply voltage as low as 1.8V and low current consumption, the TMP300 is ideal for power-sensitive systems.
Available in two micropackages that have proven thermal characteristics, this part gives a complete and simple solution for users who need simple and reliable thermal management.
评论(0)
发评论
下载排行榜
