MAX98300,pdf (Mono 2.6W Class
消耗积分:5 | 格式:rar | 大小:344 | 2010-06-20
自我清欢
分享资料个
The MAX98300 mono 2.6W Class D amplifier provides
Class AB audio performance with Class D efficiency.
This device offers five selectable gain settings (0dB,
3dB, 6dB, 9dB, and 12dB) set by a single gain-select
input (GAIN).
Active emissions limiting* edge-rate and overshoot
control circuitry greatly reduces EMI. A patented filterless
spread-spectrum modulation** scheme eliminates
the need for output filtering found in traditional Class D
devices. These features reduce application component
count.
The MAX98300 industry-leading 0.78mA at 3.7V, 1.1mA
at 5V, quiescent current extends battery life in portable
applications.
The MAX98300 is available in an 8-pin TDFN-EP (2mm
x 2mm x 0.8mm) and a 9-bump (1.2mm x 1.2mm) WLP.
Both packages are specified over the extended -40NC to
+85NC temperature range.
评论(0)
发评论
下载排行榜
