TLV320AIC1103,pdf(PCM Codec)
消耗积分:5 | 格式:rar | 大小:590 | 2010-06-23
马占云
分享资料个
The PCM codec is designed to perform transmit encoding analog/digital (A/D) conversion, receive decoding digital/analog (D/A) conversion, and transmit and receive filtering for voice-band communications systems. The device operates in either the 15-bit linear or 8-bit companded (u-law or A-Law) mode, which is selectable through the I2C interface. The PCM codec generates its own internal clocks from a 2.048-MHz master clock input.
评论(0)
发评论
下载排行榜
