PCM1795,pdf(32-Bit, 192-kHz Sa
消耗积分:5 | 格式:rar | 大小:933 | 2010-06-26
分享资料个
The PCM1795 is a monolithic CMOS integrated circuit that includes stereo digital-to-analog converters (DACs) and support circuitry in a small SSOP-28 package. The data converters use TI's advanced segment DAC architecture to achieve excellent dynamic performance and improved tolerance to clock jitter. The PCM1795 provides balanced current outputs, allowing the user to optimize analog performance externally. The PCM1795 accepts pulse code modulation (PCM) and direct stream digital (DSD) audio data formats, providing an easy interface to audio digital signal processors (DSPs) and decoder chips. The PCM1795 also interfaces with external digital filter devices such as the DF1704, DF1706, and the PMD200 from Pacific Microsonics.
评论(0)
发评论
下载排行榜
