The TLV320DAC3120 is a low-power, highly integrated, high-performance mono DAC with 24-bit mono playback.
The device integrates several analog features, such as a microphone bias, headphone drivers, and a mono speaker driver capable of driving a 4-
load. The TLV320DAC3120 has a fully programmable miniDSP for digital audio processing. The digital audio data format is programmable to work with popular audio standard protocols (I2S, left/right-justified) in master, slave, DSP, and TDM modes. Bass boost, treble, or EQ can be supported by the programmable digital-signal processing block. An on-chip PLL provides the high-speed clock needed by the digital signal-processing block. The volume level can be controlled by either a pin control or by register control.
