MUR1100 pdf,MUR1100 datasheet
消耗积分:3 | 格式:rar | 大小:555 | 2008-09-04
吴湛
分享资料个
Ultrafast “E’’ Series with High Reverse
Energy Capability
. . . designed for use in switching power supplies, inverters and as
free wheeling diodes, these state–of–the–art devices have the
following features:
• 20 mjoules Avalanche Energy Guaranteed
• Excellent Protection Against Voltage Transients in Switching
Inductive Load Circuits
• Ultrafast 75 Nanosecond Recovery Time
• 175°C Operating Junction Temperature
• Low Forward Voltage
• Low Leakage Current
• High Temperature Glass Passivated Junction
• Reverse Voltage to 1000 Volts
Mechanical Characteristics:
• Case: Epoxy, Molded
• Weight: 0.4 gram (approximately)
• Finish: All External Surfaces Corrosion Resistant and Terminal
Leads are Readily Solderable
• Lead and Mounting Surface Temperature for Soldering
Purposes: 220°C Max. for 10 Seconds, 1/16, from case
• Shipped in plastic bags, 1000 per bag
• Available Tape and Reeled, 5000 per reel, by adding a “RL’’
suffix to the part number
• Polarity: Cathode Indicated by Polarity Band
• Marking: U190E, U1100E
评论(0)
发评论
下载排行榜
