SN54HCT240, SN74HCT240,pdf(oct
消耗积分:2 | 格式:rar | 大小:616 | 2010-07-13
分享资料个
These octal buffers and line drivers are designed specifically to improve both the performance and density of 3-state memory address drivers, clock drivers, and bus-oriented receivers and transmitters. The ’HCT240 devices are organized as two 4-bit buffers/drivers with separate output-enable (OE)\ inputs. When (OE)\ is low, the device passes inverted data from the A inputs to the Y outputs. When (OE)\ is high, the outputs are in the high-impedance state.
评论(0)
发评论
下载排行榜
