SN54ALS1035, SN74ALS1035,PDF(H
消耗积分:3 | 格式:rar | 大小:464 | 2010-07-16
张杰
分享资料个
These devices contain six independent noninverting buffers. They perform the Boolean function Y = A. The open-collector outputs require pullup resistors to perform correctly. They can be connected to other open-collector outputs to implement active-low wired-OR or active-high wired-AND functions. Open-collector devices are often used to generate higher VOH levels.
评论(0)
发评论
下载排行榜
