SN74ALS29863,pdf(9-Bit Transce
消耗积分:3 | 格式:rar | 大小:247 | 2010-07-23
刘伟
分享资料个
This 9-bit transceiver is designed for asynchronous two-way communication between data buses. The control-function implementation allows for maximum flexibility in timing.
This device allows data transmission from the A bus to the B bus or from the B bus to the A bus, depending on the logic levels at the output-enable (,,, and ) inputs.
The SN74ALS29863 is characterized for operation from 0°C to 70°C.
评论(0)
发评论
下载排行榜
