SN54HCT245, SN74HCT245,pdf(OCT
消耗积分:3 | 格式:rar | 大小:707 | 2010-07-24
无人岛
分享资料个
These octal bus transceivers are designed for asynchronous two-way communication between data buses. The control-function implementation minimizes external timing requirements.
The ’HCT245 devices allow data transmission from the A bus to the B bus or from the B bus to the A bus, depending upon the logic level at the direction-control (DIR) input. The output-enable (OE)\ input can be used to disable the device so that the buses are effectively isolated.
评论(0)
发评论
下载排行榜
