SN54LS245,SN74LS245,pdf(Octal
消耗积分:5 | 格式:rar | 大小:687 | 2010-07-24
分享资料个
These octal bus transceivers are designed for asynchronous two-way communication between data buses. The control-function implementation minimizes external timing requirements.
The devices allow data transmission from the A bus to the B bus or from the B bus to the A bus, depending on the logic level at the direction-control (DIR) input. The output-enable (OE)\ input can disable the device so that the buses are effectively isolated.
评论(0)
发评论
下载排行榜
