SN54HC253,SN74HC253,pdf(DUAL 4
消耗积分:5 | 格式:rar | 大小:559 | 2010-08-11
杜喜喜
分享资料个
Each of these data selectors/multiplexers contains inverters and drivers to supply full binary decoding data selection to the AND-OR gates. Separate output-control inputs are provided for each of the two 4-line sections.
The 3-state outputs can interface with and drive data lines of bus-organized systems. With all but one of the common outputs disabled (in the high-impedance state), the low impedance of the single enabled output drives the bus line to a high or low logic level. Each output has its own output-enable (OE)\ input. The outputs are disabled when their respective OE\ is high.
评论(0)
发评论
下载排行榜
