SN54ALS137A,SN74ALS173A,SN74AS
消耗积分:5 | 格式:rar | 大小:625 | 2010-08-12
吴湛
分享资料个
The SN54ALS137A, SN74ALS137A, and SN74AS137 are 3-line to 8-line decoders/demultiplexers with latches on the three address inputs. When the latch-enable () input is low, the devices act as decoders/demultiplexers. When goes from low to high, the address present at the select (A, B, and C) inputs is stored in the latches. Further address changes are ignored as long as remains high. The output-enable controls (G1 and G2\) control the outputs independently of the select or latch-enable inputs. All of the outputs are forced high if G1 is low or G2\ is high. These devices are ideally suited for implementing glitch-free decoders in strobed (stored-address) applications in bus-oriented systems.
The SN54ALS137A is characterized for operation over the full military temperature range of -55°C to 125°C.
评论(0)
发评论
下载排行榜
