SN74HC4066,pdf(QUADRUPLE BILAT
消耗积分:5 | 格式:rar | 大小:611 | 2010-08-13
分享资料个
The SN74HC4066 is a silicon-gate CMOS quadruple analog switch designed to handle both analog and digital signals. Each switch permits signals with amplitudes of up to 6 V (peak) to be transmitted in either direction.
Each switch section has its own enable input control (C). A high-level voltage applied to C turns on the associated switch section.
Applications include signal gating, chopping, modulation or demodulation (modem), and signal multiplexing for analog-to-digital and digital-to-analog conversion systems.
评论(0)
发评论
下载排行榜
