SN65HVD1050-Q1,pdf(EMC-Optimiz
消耗积分:5 | 格式:rar | 大小:493 | 2010-08-23
分享资料个
The SN65HVD1050 meets or exceeds the specifications of the ISO 11898 standard for use in applications employing a Controller Area Network (CAN). The device is qualified for use in automotive applications.
As a CAN transceiver, this device provides differential transmit capability to the bus and differential receive capability to a CAN controller at signaling rates up to 1 megabit per second (Mbps)(1).
Designed for operation is especially harsh environments, the SN65HVD1050 features cross-wire, over-voltage, and loss of ground protection from -27 V to 40 V, over-temperature protection, a -12-V to 12-V common-mode range, and withstands voltage transients from -200 V to 200 V according to ISO 7637.
Pin 8 provides for two different modes of operation: high-speed or silent mode.
评论(0)
发评论
下载排行榜
