MAX2624 pdf,MAX2624 datasheet
消耗积分:5 | 格式:rar | 大小:666 | 2008-09-17
建立建利12
分享资料个
The MAX2622/MAX2623/MAX2624 self-contained voltage-controlled oscillators (VCOs) combine an integrated oscillator and output buffer in a miniature 8-pin µMAX® package.
The inductor and varactor elements of the tank circuits are integrated on-chip, greatly simplifying application of the part. In addition, the center frequency of oscillation and frequency span are factory preset to provide a guaranteed frequency range versus control voltage. An external tuning voltage controls the oscillation frequency. The output signals are buffered by an amplifier stage (easily matched to 50Ω), using only capacitors to provide higher output power and isolate the devices from load impedance variations.
The MAX2622/MAX2623/MAX2624 operate from a +2.7V to +3.3V supply voltage and require only 9mA of supply current. In shutdown mode, the supply current is reduced to 0.1µA.
  • Fully Monolithic
  • Guaranteed Performance
  • On-Chip 50Ω Output Match
  • Wide Choice of Frequencies
    • 855MHz to 881MHz (MAX2622)
    • 885MHz to 950MHz (MAX2623)
    • 947MHz to 998MHz (MAX2624)
  • +2.7V to +3.3V Single-Supply Operation
  • Low-Current Shutdown Mode
  • Smaller than Modules (8-pin µMAX package)
  • MAX2622 covers 855 to 881 MHz
  • MAX2623 covers 885 to 950 MHz
  • MAX2624 covers 947 to 998 MHz
  • 9 mA supply current and -8 dBm output power
  • 声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容侵权或者其他违规问题,请联系本站处理。 举报投诉
    评论(0)
    发评论
    下载排行榜
