ONET4291VA,pdf(1.0 Gbps to 4.2
消耗积分:3 | 格式:rar | 大小:634 | 2010-08-28
分享资料个
The ONET4291VA is a versatile high-speed multi-rate VCSEL driver for fiber optic applications with data rates up to 4.25 Gbps.
The device provides a 2-wire interface which allows digital control of the modulation and bias currents, eliminating the need for of external components.
The ONET4291VA includes an integrated automatic power control loop as well as circuitry to support laser safety and transceiver management systems.
The part is available in a small footprint 4 mm × 4 mm 20-pin QFN package and it requires a single 3.3-V supply.
This power efficient multi-rate VCSEL driver is characterized for operation from -40°C to 85°C ambient temperature.
评论(0)
发评论
下载排行榜
