LM4040C30/LM4040C25/LM4040C20/
消耗积分:3 | 格式:rar | 大小:774 | 2010-09-24
分享资料个
The LM4040 series of shunt voltage references are versatile, easy-to-use references that cater to a vast array of  applications. The 2-pin fixed-output device requires no external capacitors for operation and is stable with all  capacitive loads. Additionally, the reference offers low dynamic impedance, low noise, and low temperature  coefficient to ensure a stable output voltage over a wide range of operating currents and temperatures. The LM4040 uses fuse and Zener-zap reverse breakdown voltage trim during wafer sort to offer four output voltage  tolerances, ranging from 0.1% (max) for the A grade to 1% (max) for the D grade. Thus, a great deal of flexibility  is offered to designers in choosing the best cost-to-performance ratio for their applications.
评论(0)
发评论
下载排行榜
