THS9000,pdf(50 MHz to 400 MHz
消耗积分:2 | 格式:rar | 大小:446 | 2010-09-27
分享资料个
The THS9000 is a medium power, cascadeable, gain blockoptimized for high IF frequencies. The amplifier incorporates internal impedance matching to 50 Ω. The part mounted on the standard EVM achieves greater than 15-dB input and output return loss from 50 MHz to 325 MHz with VS = 5 V, R(BIAS) = 237 Ω, L(COL) = 470 nH. Design requires only two dc-blocking capacitors, one power-supply bypass capacitor, one RF choke, and one bias resistor.
评论(0)
发评论
下载排行榜
