TPS40140,pdf(Dual or 2- Phase,
消耗积分:3 | 格式:rar | 大小:1476 | 2010-10-05
overheat
分享资料个
The TPS40140 is a multi-functional synchronous buck controller that can be configured to provide either a single-output two-phase power supply or a power supply that supports two independent outputs. Several TPS40140 controllers can be stacked up to a 16-phase multi-phase single output power supply. Alternatively, several controllers providing multiple independent outputs can be synchronized in an interleaving pattern for improved input ripple current.
The TPS40140 is capable of converting from a 15-V input to a 0.7-V output at 1MHz.
Each phase operates at a switching frequency of up to 1 MHz. The two phases in one device operate 180° out-of-phase. In a multiple device stackable configuration, the phase shift of the slaves, relative to a master, is programmable.
评论(0)
发评论
下载排行榜
