TPS75103,pdf(Low Dropout, Two-
消耗积分:3 | 格式:rar | 大小:700 | 2010-10-10
胡秋阳
分享资料个
The TPS7510x linear low dropout (LDO) matching LED current source is optimized for low power keypad and navigation pad LED backlighting applications. The device provides a constant current to up to four unmatched LEDs organized in two banks of two LEDs each in a common-cathode topology. Without an external resistor, the current source defaults to factory-programmable, preset current level with ±0.5% accuracy (typical). An optional external resistor can be used to set initial brightness to user-programmable values with higher accuracy. Brightness can be varied from off to full brightness by inputting a pulse width modulation (PWM) signal on each Enable pin. Each bank has independent enable and brightness control, but current matching is done to all four channels concurrently.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
