The bq4830Y RTC Module is a non-volatile 262,144-bit SRAM organized as 32,768 words by 8 bits with an integral accessible real-time clock.
The device combines an internal lithium battery, quartz crystal, clock and power-fail chip, and a full CMOS SRAM in a plastic 28-pin DIP module. The RTC Module directly replaces industry-standard SRAMs and also fits into many EPROM and EEPROM sockets without any requirement for special write timing or limitations on the number of write cycles.
Registers for the real-time clock and clock calibration are located in registers 7FF8h\x967FFFh of the memory array.
The clock registers are dual-port read/write SRAM locations that are updated once per second by a clock control circuit from the internal clock counters.
