BQ24640,pdf(High-Efficiency Sy
消耗积分:5 | 格式:rar | 大小:689 | 2010-11-05
王树林
分享资料个
The bq24640 is highly integrated switch-mode super capacitor charge controller. It offers a constant- frequency synchronous PWM controller with high accuracy charge current and voltage regulation, and charge status monitoring.
The bq24640 charges super capacitor in two phases: constant current and constant voltage. The charge starts from down to 0V with current set on ISET pin. The charge current starts tapering down, when the voltage on VFB reaches an internal reference.
The bq24640 enters a low-current sleep mode (<15µA) when the input voltage falls below the output capacitor voltage.
The bq24640 has input CE pin to enable and disable charge, and two output pins, STAT and PG, to report charge and adapter status.
评论(0)
发评论
下载排行榜
