PT4143,pdf(20-Watt 24 V Input
消耗积分:3 | 格式:rar | 大小:181 | 2010-11-10
王敏
分享资料个
The PT4140 power modules are a series of isolated DC/DC converters housed in a low-profile package. Rated for 20 watts or 5A, the series includes standard output voltages ranging from as low as 1.5VDC to 15VDC. The output may be adjusted up to ±10% of nominal. These converters are ideal for Telecom, Industrial, Computer, and other distributed power applications that require input-to-output isolation.
Using multiple PT4140 modules, system designers can implement a complete custom power supply solution. The flexibility of full isolation also allows the input or output to be configured for negative voltage operation.
The PT4140 series requires no additional components for proper operation.
评论(0)
发评论
下载排行榜
