PT4501,pdf(20-Watt 48 V Input
消耗积分:10 | 格式:rar | 大小:211 | 2010-11-11
分享资料个
The PT4500 Excalibur™ power modules are a series of isolated DC/DC converters housed a new space-saving copper case. The series includes a number of standard output voltages ranging from as low as 1.2VDC to 15VDC, each adjustable by up to 10% of nominal. The modules are ideal for Telecom, Industrial, Computer, and other distributed power applications that require input-to-output isolation.
Using multiple modules,system designers can implement a complete custom power supply solution. The flexibility of full isolation also allows the input or output to be configured for negative voltage operation.
The PT4500 series is electrically equivalent to th popular PT4140 series and requires no additional components for proper operation.
评论(0)
发评论
下载排行榜
