基于MC56F8323的步进电机高速细分驱动模块
消耗积分:10 | 格式:rar | 大小:6943 | 2010-12-08
绝代双骄
分享资料个
针对工业界电机平稳高速运转的需要,设计了两相步进电机高速细分驱动模块。模块采用256步进细分实现步进电机的平稳工作,采用指令周期短的MC56F8323,压缩步进处理指令数,尽量降低步进脉冲的响应时间,实现步进电机的高速运转控制。
Abstract:
 Taking aim at requirement of Running Stability? of high speed motor ,a high speed microstep drive circuit of the 2-phase stepping motor was designed.Based on MC56F8323 with shorter instruction cycle,the stepping motor system provided selectable subdividing up to 256,the Instruction Set is decreased,stepping pulse response time is? reduced,controlling of the high speed motor is implemented.
评论(0)
发评论
下载排行榜
