针对定时控制无法应付交通流无规律的交叉路口,设计以CPLD为控制核心的单交叉路口半感应控制器。采用层次化设计思想,使用VHDL语言编写控制部分的主程序,并通过MAXPLUSⅡ软件进行仿真。仿真结果显示,系统可实现单个交叉路口交通信号灯的半感应控制,并且系统的控制参数可通过外部输入调节,增加系统的灵活性。
- Abstract:
- For the timing control is unable to cope with erratic traffic flow of intersection,this paper designs a single-crossing semi-sensing controller with core of CPLD.Using hierarchical design means designs the program of controller with VHDL,and simulates with software of MAXPLUSⅡ.The results of simulation show that this system can achieve semi-sensing control of a single intersection traffic signal.And system parameters can be changed through external input regulation,increasing flexibility of the system.
