At 125Msps and an input frequency of 200MHz, the MAX1217 achieves an 80dBc spurious-free dynamic range (SFDR) with excellent 65.3dB signal-to-noise ratio(SNR) at 200MHz. The SNR remains flat (within 3dB) for input tones up to 200MHz. This makes the MAX1217 ideal for wideband applications such as communications receivers, cable head-end receivers, and power-amplifier predistortion in cellular base-station transceivers.
The MAX1217 operates from a single 1.8V power supply. The analog inputs of each channel are designed for AC-coupled, differential or single-ended operation. The ADC also features a selectable on-chip divide-by-2 clock circuit that accepts clock frequencies as high as 250MHz and reduces the phase noise of the input clock source. A low-voltage differential signal (LVDS) sampling clock is recommended for best performance. The converter's digital outputs are LVDS compatible and the data format can be selected to be either two's complement or offset binary.
The MAX1217 is available in a 100-pin TQFP package with exposed paddle and is specified over the extended (-40°C to +85°C) temperature range. Refer to the MAX1218 (170Msps) and the MAX1219 (210Msps) data sheets for higher speed, pin-compatible devices.
