MAX3228E,MAX3229E pdf datasheet (RS-232 Transceivers in UCSP
消耗积分:3 | 格式:rar | 大小:333 | 2008-11-15
分享资料个
The MAX3228E/AE and MAX3229E/AE are +2.5V to
+5.5V powered EIA/TIA-232 and V.28/V.24 communications
interfaces with low power requirements, high datarate
capabilities, and enhanced electrostatic discharge
(ESD) protection, in a chip-scale package (UCSP™)
and WLP Package. All transmitter outputs and receiver
inputs are protected to ±15kV using IEC 1000-4-2 Air-
Gap Discharge, ±8kV using IEC 1000-4-2 Contact
Discharge, and ±15kV using the Human Body Model.
The MAX3228E/AE and MAX3229E/AE achieve a 1μA
supply current with Maxim’s AutoShutdown™ feature.
They save power without changes to existing BIOS or
operating systems by entering low-power shutdown
mode when the RS-232 cable is disconnected, or when
the transmitters of the connected peripherals are off.
The transceivers have a proprietary low-dropout transmitter
output stage, delivering RS-232 compliant performance
from a +3.1V to +5.5V supply, and RS-232
compatible performance with a supply voltage as low
as +2.5V. The dual charge pump requires only four
small 0.1μF capacitors for operation from a +3.0V supply.
Each device is guaranteed to run at data rates of
250kbps while maintaining RS-232 output levels.
The MAX3228E/AE and MAX3229E/AE offer a separate
power-supply input for the logic interface, allowing configurable
logic levels on the receiver outputs and transmitter
inputs. Operating over a +1.65V to VCC range, VL
provides the MAX3228E/AE and MAX3229E/AE compatibility
with multiple logic families.
The MAX3229E/AE contains one receiver and one
transmitter. The MAX3228E/AE contains two receivers
and two transmitters. The MAX3228E/AE and
MAX3229E/AE are available in tiny chip-scale and WLP
packaging and are specified across the extended
industrial temperature range of -40°C to +85°C.
评论(0)
发评论
下载排行榜
