MAX3000E/MAX3001E在VCC一侧的I/O具有±15kV ESD保护,在外部信号切换应用场合提供更强的保护。MAX3000E能够可靠工作在230kbps的数据速率下;MAX3001E确保数据速率达4Mbps;MAX3002–MAX3012在整个工作电压范围内可提供20Mbps的数据速率。
MAX3000E/MAX3001E/MAX3002–MAX3012的VL电压范围为+1.2V至+5.5V,VCC电压范围为+1.65V至+5.5V。这对于低电压ASIC/PLD与高电压系统之间的数据传输非常理想。MAX3000E/MAX3001E/MAX3002”MAX3012采用20引脚UCSP™封装或20引脚TSSOP封装。
The MAX3000E/MAX3001E/MAX3002–MAX3012
8-channel level translators provide the level shifting necessary
to allow data transfer in a multivoltage system.
Externally applied voltages, VCC and VL, set the logic levels
on either side of the device. Logic signals present on
the VL side of the device appear as a higher voltage logic
signal on the VCC side of the device, and vice-versa.
The MAX3000E/MAX3001E/MAX3002/MAX3003 use an
architecture specifically designed to be bidirectional
without the use of a directional pin.
The MAX3000E/MAX3001E/MAX3002/MAX3004–MAX3012
feature an EN input that, when low, reduces the VCC and
VL supply currents to < 2μA. The MAX3000E/MAX3001E
also have ±15kV ESD protection on the I/O VCC side for
greater protection in applications that route signals
externally. The MAX3000E operates at a guaranteed data
rate of 230kbps. The MAX3001E operates at a guaranteed
data rate of 4Mbps. The MAX3002–MAX3012 operate at a
guaranteed data rate of 20Mbps over the entire specified
operating voltage range.
The MAX3000E/MAX3001E/MAX3002–MAX3012 accept
VL voltages from +1.2V to +5.5V and VCC voltages from
+1.65V to +5.5V, making them ideal for data transfer
between low-voltage ASICs/PLDs and higher voltage
systems. The MAX3000E/MAX3001E/MAX3002–
MAX3012 are available in 20-bump UCSP™, 20-pin
TQFN (5mm x 5mm), and 20-pin TSSOP packages.
