DS9016 pdf datasheet (500mA Pe
消耗积分:5 | 格式:rar | 大小:333 | 2008-12-11
李明
分享资料个
The RT9016 is designed for portable RF and wireless
applications with demanding performance and space
requirements. The RT9016 performance is optimized for
battery-powered systems to deliver ultra low noise and
low quiescent current. A noise bypass pin is available for
further reduction of output noise. Regulator ground current
increases only slightly in dropout, further prolonging the
battery life. The RT9016 also works with low-ESR ceramic
capacitors, reducing the amount of board space necessary
for power applications, critical in hand-held wireless
devices. The RT9016 consumes less than 0.01μA in
shutdown mode and has fast turn-on time less than 50μs.
RT9016 is short circuit thermal folded back protected.
RT9016 lowers its OTP trip point from 165°C to 110°C
when output short circuit occurs (VOUT < 0.4V) providing
maximum safety to end users. The other features include
ultra low dropout voltage, high output accuracy, current
limiting protection, and high ripple rejection ratio. Available
in the SOT-23-5 and WDFN-6L 2x2 packages.
评论(0)
发评论
下载排行榜
