PCM3006 pdf datasheet (16-Bit,
消耗积分:3 | 格式:rar | 大小:333 | 2008-12-18
张国厚
分享资料个
The PCM3006 is a low cost single chip stereo audio
CODEC (analog-to-digital and digital-to-analog converters)
with single-ended analog voltage input and
output.
Both ADCs and DACs employ delta-sigma modulation
with 64X oversampling. The ADCs include a
digital decimation filter, and the DACs include an 8X
oversampling digital interpolation filter. The DACs
also include a de-emphasis function. PCM3006 operates
with 16-bit, left-justified for ADC, right-justified
for DAC data formats.
PCM3006 provides a Power-Down Mode that operates
on the ADCs and DACs independently.
Fabricated on a highly advanced 0.6ms CMOS process,
PCM3006 is suitable for a wide variety of
cost-sensitive consumer applications where good
performance is required. Applications include sampling
keyboards, digital mixers, effects processors,
hard-disk recorders, data recorders and digital video
cameras.
评论(0)
发评论
下载排行榜
