EL8202, EL8203, EL8403 pdf dat
消耗积分:2 | 格式:rar | 大小:544 | 2009-01-17
分享资料个
The EL8202, EL8203, and EL8403 represent rail-to-rail
amplifiers with a -3dB bandwidth of 500MHz and slew rate of
600V/μs. Running off a very low supply current of 5.6mA per
channel, the EL8202, EL8203, and EL8403 also feature
inputs that go to 0.15V below the VS- rail. The EL8202 and
EL8203 are dual channel amplifiers. The EL8403 is a quad
channel amplifier.
The EL8202 includes a fast-acting disable/power-down
circuit. With a 25ns disable and a 200ns enable, the EL8202
is ideal for multiplexing applications.
The EL8202, EL8203, and EL8403 are designed for a
number of general purpose video, communication,
instrumentation, and industrial applications. The EL8202 is
available in a 10 Ld MSOP package, the EL8203 in 8 Ld SO
and 8 Ld MSOP packages, and the EL8403 in 14 Ld SO and
16 Ld QSOP packages. All are specified for operation over
the -40°C to +85°C temperature range.
评论(0)
发评论
下载排行榜
