MAX9669 pdf datasheet (10-Bit
消耗积分:10 | 格式:rar | 大小:333 | 2009-02-08
tr12345
分享资料个
The MAX9669 outputs 16 voltage references for gamma correction in TFT LCDs and one voltage reference for VCOM. Each gamma reference voltage has its own 10-bit digital-to-analog converter (DAC) and buffer to ensure a stable voltage. The VCOM reference voltage has its own 10-bit DAC and an amplifier to ensure a stable voltage when critical levels and patterns are displayed. The MAX9669 features integrated multiple-time programmable (MTP) memory to store gamma and VCOM values on the chip, eliminating the need for external EEPROM. The MAX9669 supports up to 100 write operations to the on-chip nonvolatile memory.
The gamma outputs can drive 250mA peak transient current and settle within 1µs. The VCOM output can provide 400mA peak transient current and also settles within 1µs. The analog supply voltage range extends from 9V to 20V, and the digital supply voltage range extends from 2.7V to 3.6V.
Gamma values and the VCOM value are programmed into registers through the I²C interface.
  • 16-Channel Gamma Correction, 10-Bit Resolution
  • VCOM Driver
  • Integrated MTP Memory
  • Programmable VCOM Limits
  • 250mA Peak Current on Gamma Channels
  • 400mA Peak Current on VCOM Channel
  • 1µs Settling Time
  • 声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容侵权或者其他违规问题,请联系本站处理。 举报投诉
    评论(0)
    发评论
    下载排行榜
