ISL97519 pdf datasheet (1% Out
消耗积分:2 | 格式:rar | 大小:555 | 2009-03-05
李杰
分享资料个
The ISL97519 is a high frequency, high efficiency step-up
voltage regulator operated at constant frequency PWM
mode. With an internal 2.0A, 200mΩ MOSFET, it can deliver
up to 1A output current at over 90% efficiency. The
selectable 600kHz and 1.2MHz allows smaller inductors and
faster transient response. An external compensation pin
gives the user greater flexibility in setting frequency
compensation allowing the use of low ESR ceramic output
capacitors.
When shut down, it draws <1μA of current and can operate
down to 2.3V input supply. These features along with
1.2MHz switching frequency makes it an ideal device for
portable equipment and TFT-LCD displays.
The ISL97519 is available in an 8 Ld MSOP package with a
maximum height of 1.1mm. The device is specified for
operation over the full -40°C to +85°C temperature range.
评论(0)
发评论
下载排行榜
