The AP3765 is a high performance AC/DC power supply
controller for battery charger and adapter applications.
The device uses Pulse Frequency Modulation
(PFM) method to build discontinuous conduction
mode (DCM) flyback power supplies.
The AP3765 provides accurate constant voltage, constant
current (CV/CC) regulation while removing the
opto-coupler and secondary control circuitry. It also
eliminates the need of loop compensation circuitry
while maintaining stability. The AP3765 achieves
excellent regulation and high average efficiency, yet
meets the requirement for no-load consumption less
than 30mW.
