TPS56221,pdf (25A High Current Synchronous Step-Down SWIFT Co
消耗积分:0 | 格式:pdf | 大小:322 KB | 2011-04-07
dplion
分享资料个
TPS56221 is a high-efficiency and high-current synchronous buck converter designed to operate from a supply between 4.5 V and 14 V. The device is capable of producing an output voltage as low as 0.6 V at loads up to 25 A. Integrated NexFET™ Power MOSFETs provide a small footprint and ease of use.
The device implements a voltage-mode control with voltage feed-forward compensation that responds instantly to input voltage change.
TPS56221 is available in a thermally enhanced 22-pin PQFN (DQP) PowerPAD™ package.
The device offers design flexibility with a variety of user programmable functions, including soft-start, overcurrent protection (OCP) levels, and loop compensation.
评论(0)
发评论
下载排行榜
