MPC106 PCI Bridge/Memory Contr
消耗积分:0 | 格式:rar | 大小:333 | 2009-04-02
张静
分享资料个
In this document, the term Ô60xÕ is used to denote a 32-bit microprocessor from the PowerPC architecture family that conforms to the bus interface of the PowerPC 601ª, PowerPC 603ª, or PowerPC 604 microprocessors. Note that this does not include the PowerPC 602ª microprocessor which has a multiplexed address/data bus. 60x processors implement the PowerPC architecture as it is speciÞed for 32-
bit addressing, which provides 32-bit effective (logical) addresses, integer data types of 8, 16, and 32 bits,and ßoating-point data types of 32 and 64 bits (single-precision and double-precision).
1.1 Overview The MPC106 provides an integrated high-bandwidth, high-performance, TTL-compatible interface between a 60x processor, a secondary (L2) cache or additional (up to four total) 60x processors, the PCI bus,and main memory. This section provides a block diagram showing the major functional units of the 106 and describes brießy how those units interact.
Figure 1 shows the major functional units within the 106. Note that this is a conceptual block diagram intended to show the basic features rather than an attempt to show how these features are physically implemented on the device.
评论(0)
发评论
下载排行榜
