LT1300和LT1301在功率DCDC转换器中的应用
消耗积分:0 | 格式:pdf | 大小:582 KB | 2011-12-30
分享资料个
The design of battery-powered equipment can often bequite challenging. Since few ICs can operate directly fromthe end-of-life voltage from a 2-cell battery (about 1.8V),most systems require a DC/DCconverter. The systemdesigner often has a limited area in which to place the DC/DC converter; associated inductors and capacitors must be
small. Surface mount components are a must and heatsinks are out of the question! The LT1300 and LT1301micropower DC/DC converter ICs provide new possibilitiesfor more efficient, compact and cost effective designs.When designing equipment for battery-poweredoperation, a number of important design constraintsshould be considered. Some of these are detailed in thecheck list given here:
评论(0)
发评论
下载排行榜
