简单、高效USB电源管理IC解决方案
消耗积分:1 | 格式:pdf | 大小:55 KB | 2012-02-03
分享资料个
Linear Technology offers a variety of devices that simplifyconverting power from a USB cable, but the LTC®3455represents the highest level of functional integration yet. The LTC3455 seamlessly manages power flowbetween an AC adapter, USB cable and Li-ion battery,while complying with USB power standards, all from a4mm × 4mm QFN package. In addtion, two high efficiencysynchronous buck converters generate low voltage railswhich most USB-powered peripherals require. TheLTC3455 also provides power-on reset signals for themicroprocessor, a Hot SwapTM output for poweringmemory cards as well as an uncommitted gain blocksuitable for use as a low-battery comparator or an LDOcontroller. The PCB real estate required for the entire USBpower control circuit and two DC/DC converters is only225mm2.
评论(1)
发评论
ltm0610doing 2014-06-13
0 回复 举报
谢谢分享 收起回复
下载排行榜
全部1条评论
