MAX4968,MAX4968A数据手册
消耗积分:0 | 格式:pdf | 大小:460 KB | 2012-07-03
分享资料个
The MAX4968/MAX4968A are 16-channel, high-linearity,high-voltage, bidirectional SPST analog switches with18I (typ) on-resistance. The devices are ideal for use inapplications requiring high-voltage switching controlledby a low-voltage control signal, such as ultrasound imagingand printers. The MAX4968A provides integrated40kI (typ) bleed resistors on each switch terminal todischarge capacitive loads. Using HVCMOS technology,these switches combine high-voltage bilateral MOSswitches and low-power CMOS logic to provide efficientcontrol of high-voltage analog signals.
评论(0)
发评论
下载排行榜
