全英版SN74HC573A DBR_datasheet
消耗积分:1 | 格式:pdf | 大小:290KB | 2014-08-08
jin201142410
分享资料个
These octal transparent D-type latches feature 3-state outputs designed specifically for driving highly capacitive or relatively low-impedance loads。They are particularly suitable for implementing buffer registers, I/O ports,bidirectional bus drivers, and working registers。While the latch-enable (LE) input is high,the Q outputs respond to the data (D) inputs。When LE is low,the outputs are latched to retain the data that was set up。
评论(0)
发评论
下载排行榜
