LM4050, LM4051,pdf datasheet (
消耗积分:5 | 格式:rar | 大小:433 | 2009-09-05
南风一号
分享资料个
The LM4050/LM4051 are precision two-terminal, shuntmode,
bandgap voltage references available in fixed
reverse breakdown voltages of 1.225V, 2.048V, 2.500V,
3.000V, 3.3V, 4.096V, and 5.000V. Ideal for space-critical
applications, the LM4050/LM4051 are offered in the
subminiature 3-pin SC70 surface-mount packages
(1.8mm x 1.8mm), 50% smaller than comparable
devices in SOT23 surface-mount package (SOT23 versions
are also available).
Laser-trimmed resistors ensure excellent initial
accuracy. With a 50ppm/°C temperature coefficient,
these devices are offered in three grades of initial accuracy
ranging from 0.1% to 0.5%. The LM4050/LM4051
have a 60μA to 15mA shunt-current capability with low
dynamic impedance, ensuring stable reverse breakdown
voltage accuracy over a wide range of operating
temperatures and currents. The LM4050/LM4051 do
not require an external stabilizing capacitor while
ensuring stability with any capacitive loads.
The LM4050/LM4051 specifications are guaranteed
over the temperature range of -40°C to +125°C.
________________________Applications
Portable, Battery-Powered Equipment
Notebook Computers
Cell Phones
Industrial Process Controls
评论(0)
发评论
下载排行榜
