MM54HC00/MM74HC00,pdf datashee
消耗积分:3 | 格式:rar | 大小:322 | 2009-09-19
分享资料个
These NAND gates utilize advanced silicon-gate CMOS
technology to achieve operating speeds similar to LS-TTL
gates with the low power consumption of standard CMOS
integrated circuits. All gates have buffered outputs. All devices
have high noise immunity and the ability to drive 10
LS-TTL loads. The 54HC/74HC logic family is functionally
as well as pin-out compatible with the standard 54LS/74LS
logic family. All inputs are protected from damage due to
static discharge by internal diode clamps to VCC and ground.
评论(0)
发评论
下载排行榜
