LP38511-ADJ,pdf datasheet (800
消耗积分:2 | 格式:rar | 大小:555 | 2009-10-05
分享资料个
The LP38511-ADJ Fast-Transient Response Low-Dropout
Voltage Regulator offers the highest-performance in meeting
AC and DC accuracy requirements for powering Digital
Cores. The LP38511-ADJ uses a proprietary control loop that
enables extremely fast response to change in line conditions
and load demands. Output Voltage DC accuracy is guaranteed
at 2.5% over line, load and full temperature range from
-40°C to +125°C. The LP38511-ADJ is designed for inputs
from the 2.5V, 3.3V, and 5.0V rail, is stable with 10 uF ceramic
capacitors, and has an adjustable output voltage. The
LP38511-ADJ provides excellent transient performance to
meet the demand of high performance digital core ASICs,
DSPs, and FPGAs found in highly-intensive applications such
as servers, routers/switches, and base stations.
评论(0)
发评论
下载排行榜
