LM6588,pdf datasheet (TFT-LCD
消耗积分:3 | 格式:rar | 大小:552 | 2009-10-07
分享资料个
The LM6588 is a low power, high voltage, rail-to-rail inputoutput
amplifier ideally suited for LCD panel VCOM driver and
gamma buffer applications. The LM6588 contains four unity
gain stable amplifiers in one package. It provides a common
mode input ability of 0.5V beyond the supply rails, as well as
an output voltage range that extends to within 50mV of either
supply rail. With these capabilities, the LM6588 provides
maximum dynamic range at any supply voltage. Operating
on supplies ranging from 5V to 16V, while consuming only
750μA per amplifier, the LM6588 has a bandwidth of 24MHz
(−3dB).
评论(0)
发评论
下载排行榜
