LM8261,pdf datasheet (RRIO, Hi
消耗积分:3 | 格式:rar | 大小:550 | 2009-10-07
李鸿
分享资料个
The LM8261 is a Rail-to-Rail input and output Op Amp which
can operate with a wide supply voltage range. This device has
high output current drive, greater than Rail-to-Rail input common
mode voltage range, unlimited capacitive load drive
capability, and provides tested and guaranteed high speed
and slew rate while requiring only 0.97mA supply current. It
is specifically designed to handle the requirements of flat panel
TFT panel VCOM driver applications as well as being suitable
for other low power, and medium speed applications
which require ease of use and enhanced performance over
existing devices.
评论(0)
发评论
下载排行榜
