伺服电机和控制Arduino平台
消耗积分:0 | 格式:rar | 大小:0.14 MB | 2017-05-02
分享资料个
  伺服电机和控制Arduino平台
  在这篇文章中,我们将讨论以下:
  什么是伺服电机?
  它们是如何起作用的?(基本驾驶方法和技术)
  如何选择伺服电机应用
  Arduino平台工作
  What is a servo motor?
  What is a servo motor, where are they used, what are they made of and, how do they function?
  A servo motor is a motor whose shaft turns to position something based off a control signal. They are typically used to steer remote control airplanes by adjusting the wing flaps, flight position for drones, controlling valves used in flow control or continuous drive of wheels for robots. They can be used to position or adjust almost anything you can think of. They consist of a plastic housing which contains a DC motor, a control circuit and a few gears for torque (see Figure 1).
评论(1)
发评论
chan_jt2005 2018-01-21
0 回复 举报
谢谢啦。好东西啦 收起回复
下载排行榜
全部1条评论
