TheISSIIS62C256AL/IS65C256AL isalowpower,32,768 word by 8-bit CMOS static RAM. It is fabricated using ISSI‘s high-performance, low power CMOS technology. When CE is HIGH (deselected), the device assumes a standby mode at which the power dissipation can be reduced down to 150 µW (typical) at CMOS input levels. Easy memory expansion is provided by using an active LOW Chip Select (CE) input and an active LOW Output Enable (OE) input. The active LOW Write Enable (WE) controls both writing and reading of the memory. TheIS62C256AL/IS65C256ALispincompatiblewithother 32Kx8 SRAMs in plastic SOP or TSOP (Type I) package.
