led7708升压控制器和四线16通道×85毫安的LED驱动串行接口数据表
消耗积分:0 | 格式:rar | 大小:0.84 MB | 2017-09-25
分享资料个
  The LED7708 has been specifically designed to supply several LEDs starting from a single lowvoltage rail. It integrates a boost controller, sixteen current generators and a 4-wire serial interface. The boost controller regulates the output voltage in an adaptive way, according to the LED requirements, resulting in an improved overall efficiency. All the current generators are 40 V-rated, allowing the LED7708 to drive several LEDs in series on each channel. The channels can be put in parallel for higher output current. The brightness of the LEDs is controlled by using the serial interface. A selectable 12-bit or 16-bit grayscale brightness control allows independent PWM on each channel. A programmable on-chip dimming oscillator is provided for external circuitry simplification. The device has dedicated pins to lock to an external synchronization with other devices (master or slave) for noise reduction in multi-device applications. The LED7708 implements basic protection (OVP, OCP and thermal shutdown) as well as LED array protection. It can detect and manage open-LED and shorted-LED faults and different faultmanagement options are available in order to cover most application needs.
评论(0)
发评论
下载排行榜
